My customer wants to achieve best performance of AEQ even though lock time gets longer.
Could you provide AEQ register configuration to get best AEQ performance?
Customer uses coax cable with 2m length.
Manickam-san,
Thanks for your reply.
This time, manual setting requiremnt is only for EMI measurement purpose.
So could you provide information about EQ_STAGE_1_SELECT_VALUE and EQ_STAGE_2_SELECT_VALUE ahd procedure how to configure these parameters correctly?
Of course, for actual application use, I recommend to use AEQ not manual EQ.
Best regards
Manickam-san,
Thanks for you reply.
Let me confirm, as a starting point,is it correct with following setupt?
EQ_STAGE_1_SELECT_VALUE = EQ_STATUS[5:3]
EQ_STAGE_2_SELECT_VALUE = EQ_STATUS[2:0]
ADAPTIVE_EQ_BYPASS = '1'
