I’m trying to use the IBIS model from the TI website to run a simulation in ADS with the TCA9617B, but I’m having trouble implementing it. Is there an example you can show of how I’d use the IBIS model in a simulation, or at least tell me how to set up the model with the correct part in ADS? I’m just trying to do a simulation with an input of a typical clock signal, and then look at what the output will be depending on the stub seen and pull up resistors used. Any help is appreciated, thank you.
