Hi Sirs,
Sorry to bother you.
We have use TI TCA6424A, need check I2C setting.
If we setting I2C address is 22 (Hex)
How could we setting low at P01 (output port 01)??
Our step is
1. Into I2C address 22(0x22)
2. Command byte register 0x84
3. The last data to register 0x00
Am i wrong??
Because we do that, the register to read is correct, but the output level always high.
So should we need config I/O state then to setting command byte?
Or could you teach us how to setting P01 to low??
Thanks for your reply
