Dear Team:
Our customer used 2pcs TCA9617A in server application, and circuit is as attached.
Customer got strange phenomenon: A side no signal input that is only pull high, but B side got toggle waveform. (data and clock pin got same phenomenon.)
Could you reply customer questions:1. A side voltage should under B side?
2.Two pcs TCA9617 B side could not series connect it together, right?
3.What is the toggle output root cause?
1st waveform is B side clk. 2nd waveform is B side clk zoom in.
