Other Parts Discussed in Thread: TCA9617A
Hi Team:
Need your help to check whether the waves are right.
Below is the connection block:
The master output wave is good. But the port A clock will have a step:
Could you tell me why will have a step? Due to I2C will check voltage level to see the "0" or "1". Whether will cause potential risk?
When the I2C send out, the slave will reponse. But the slave signal will be like below:
Why the response signal can't get zero level, will always have 500mV bias? Thanks.
