Hello Team;
Could you specify what is Low Standby current mode for TCA6418E?
The datasheet "FEATURES" specify "• Low Standby (Idle) Current Consumption: 3 μA", but no detail for this mode..
Macs - Japan CSC
Hello Team;
Macs - Japan CSC
Hello Mac,
I am not sure if you are new to E2E but the fastest way to get an answer to a question is to search E2E. I simply typed "Standby Current Mode" and got 15+ results in a matter of seconds. The forum is a database of questions asked and answered. If you look through the search results and don't find an answer then post to the forum and we will be happy to answer the questions, especially since it may have not been asked before. We are always looking to expand the database, but not with duplicate answers or questions.
Here is the link to a post that answers your questions:
e2e.ti.com/.../457085 current
-Francis Houde
Hello Francis-san,
Thank you for your reply. I understand your point what you would like to say.
However, I did check E2E and I could not find information what I(and our customer) would like to know.
The point what customer wish to know, is , "Low Standby (Idle) Current Consumption: 3 μA" is written on
features on datasheet top, However, there is no specification written on "Electrical Characteristic".
I think condition of this spec., is same as Icc Spec. with fscl=0 kHz, however, specification is 13uA(Max), and
no typical data written. So, question is, where the "3uA" comes from?
The customer would like to use in "Wearable product",so it require very low power, so that he would like to minimize
power consumption while it is not used(Idle time).
And he need to confirm minimum power consumption for this device.
Could you inform what is idle current in typical and Maximum if you have, and confirm test condition is same as
Icc measurement spec.?
Macs-Japan CSC
Hi Max-san
Thank you for your support. I shall waiting your reply.
By the way,
Do you have typical number of Icc with 400kHz and 1Mhz SCL? just in case if you have.
Otherwise I can reply to customer that "We do not have".
Best Regards.
Macs
