Other Parts Discussed in Thread: TCA6416A, PCA9306
Hi Support Team
Customer has a questions regarding the open drain outputs. Data sheet specifically states that open drain output must be pulled up to VCC. If the customer has a multi rail system, can the pull to open drain output up to a different rail?
Examples, TCA9555 at 5 volts, micro at 1.8v, or TCA9555 at 2.5v and micro at 3,3v. Also are we save if the rail that the pull up is connected to come up before the rail that powers the TCA9555 ?
Jeff Coletti
