Hi all
Would you mind if we ask TCA9517A?
How much are the maximum absolute rating of TJ and TC?
We could not find these on the datasheet.
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Hello Matsumoto-san,
TI does not specify the part in terms of abs max junction temperature. Generally speaking it is the same as max storage temperature, but note that it isn't expected to operate properly at those temperatures outside of max operating temperature. I am in the process of reviewing our process specifications for that part and can confirm this in a day or two.
-Francis Houde
Sorry for the delay. Here is what I found out. If the part is unpowered then the abs max junction temperature is 150C with no effect to the Failure In Time (FIT) rate. If you expose the part to great than 105C you will increase the FIT rate. a little.
Hope this answers your question.
-Francis Houde
