Other Parts Discussed in Thread: LDC2114
I'd like to controll 8 LDC2114, which all have the same I2C address by using the tca9548a. An MSP430 is master. The MSP430 communicats directly to the LDC2114 and cannot controll the tca9548a, because it's firmware is fixed and should not be changed.
That's why I plan to controll the tca9548a by a second microcontroller, which only has the task to controll the tca9548, depending on an 8-dip switch's position.
So depending on the dip's position, the MSP430 communicats the the respective LDC2114. Is this possible?
I'v attached a block diagram for better understanding.
Thank you very much, and kind regards,
Clemens
