• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Industrial Interface » Industrial Interface Forum » Intermittent behavior of DS26LV32AT
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is answered
Jeffrey Bledsoe
Posted by Jeffrey Bledsoe
on Dec 17 2011 13:00 PM
Prodigy80 points
I hope this is the right place to post this question. If not, please let me know where to go next.
This part is used in a basically unterminated configuration. There is a series resistor (each 590 Ohms) on each input; also, between each resistor and each input to the part, there's a transzorb connected to ground. It's a very low frequency application and the cable is only a few feet long. I believe the driver is a DS26LV31 but I'm not sure. (In the lab, I used an Agilent 8116A pulse generator.)
There's errant behavior in one installation of this part. It's going to a Vo = L state with an open circuit on the inputs*. It's an intermittent that can't be duplicated; it seems to be happening randomly and only after long periods of operating normally. In one case, it seemed that shorting the input* caused it to go to the V0 = L state after removing the short.
So, I continued trying to come up with a way to reliably induce the failure.
Just for information (I know a certain range of common mode voltage on both pins with the pins shorted is an area of concern with this part) I tried driving the + side of the pulse generator into both inputs*. (The pulse generator and the part have common grounds.) With this configuration, and varying the amplitude of the input from 5V to 1V (10Vpp wrt ground), the part's output was at a constant "L" state for a certain range of input amplitude. So, I tried the same test on another installation (an installation that hasn't exhibited the random failures described above) of the part and there were no cases of amplitude that resulted in a constant "L" on that part's output.
Any ideas what might be going on here? Just a failed part that has failed in a rare mode? Any suggestions for other tests to try?
Jeff
* input: input to the inline resistors, not the part's input pins
DS26LV32AT common mode voltage failure unterminated
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Dec 17 2011 13:30 PM
    Guru101915 points
    Hey, Jeff,
    It seems like the Industrial Interface forum might be the right place for your post (I'm not 100% sure...). Let me move it there for you.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    Posted by Thomas Kugelstadt
    on Dec 20 2011 15:45 PM
    Verified Answer
    Verified by Thomas Kugelstadt
    Mastermind25560 points
    Jeff,
    the DS26LV32 is a differential receiver which detects logic states based only on the differential input voltage, Vid, and NOT with regards to ground. Its input sensitivity is +/- 200mV which means for the receiver output to go High the input voltage at RI+ must be 200mV more positive than the input voltage at RI- and for the receiver output to go Low the input voltage at RI+ must be 200mV more negative than the input voltage at RI-. Any Vid in between those values will cause undetermined output states, meaning the output might be High or Low or might even toggle.
    Tolerances in device manufacturing can lead to slight deviations in the input attenuators as well as in the hysteresis of the internal differential comparator between devices.
    Thus applying 0V Vid to the inputs of one receiver might yield a Low, while applied to another receiver might yield a High. In the test setup you are describing you are applying 0V Vid to each tested receiver. Therefore your measurement results are plausible.
    I suggest using failsafe biasing as shown in the application section of the data sheet. Thus when the driver should go high-impedance, you will always have a defined Vid at the receiver input. Since you explained that your application is only a few feet long and operates at low data rates you might not need a 100 ohms termination and thus your failsafe biasing network could have some higher impedance, such as 3 x 4.7k resistors.
    Also the 590 ohms resistor before the transorbs are not clear to me. When the transorbs conduct they are supposed to divert high currents to ground. You don't want to limit the current before the transorb but after the transorb. Depending on the type of transorbs, they can develop a clamping voltage that is higher than the maximum specified input voltage of 14V. In this case you want to limit the current into the device inputs. Also when expecting high transient overvoltages you want to look into MELF resistors or high-voltage resistors as the standoff voltage for normal SMD resistors is often limited to 200V.
    Regards, Thomas
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Dec 20 2011 23:00 PM
    Jeff,
    just want to mention you don't need the middle 4.7k resistor. It's a habit of mine using 3 resistors for failsafe biasing which only makes sense if the middle resistor is your termination resistor. However in your case you simply need to pull the A and B lines up and down respectively.
    Thomas
    Report Abuse
    • Reply
  • Jeffrey Bledsoe
    on Dec 22 2011 13:21 PM
    Prodigy80 points
    The driver's signal level is RS485 & the differential driver device used is a 5962-9076502MFA.
    I'm trying to find out if the driver has a bias circuit. According to the RS-485 thread on Wikipedia, that's a common/acceptable practice.
    Jeff
    Report Abuse
    • Reply
  • Jeffrey Bledsoe
    on Feb 15 2012 09:34 AM
    Prodigy80 points
    Thomas,
    My circuit actually has 2 receivers connected as shown in the picture here. When everything is working properly with V1 = V2 = logic 1, Vin = + 380 mV with a DMM. When the phenomenon occurs, one of the outpus goes to logic 0 (fail), the other remains at logic 1 (good). Unfortunately, I didn't get a Vin reading for the case when the failure is occurring.
    Could one chip's bias circuits be supporting the other chip's failed (or marginal) bias circuits via their connections shown in the diagram?
    I'll separate the receivers and gather some more voltage information.
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Feb 15 2012 09:44 AM
    Jeff,
    firstly, please change the location of your input resistors. Apply them past the Transzorbs as I suggested in my previous schematic.
    The check whether the phenomenon still occurs.
    Thank you,
    Thomas
    Report Abuse
    • Reply
  • Jeffrey Bledsoe
    on Feb 16 2012 13:50 PM
    Prodigy80 points
    The transzorbs were placed at the part's input pins to provide overvoltage protection for the part. The resistors were placed before the transzorb to provide overcurrent protection for the transzorbs.
    Jeff
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Feb 16 2012 14:55 PM
    1) You protect Tranzorbs with MOVs and Pulse resistors, not just ressistor.
    2) For your application choose 400 W to 600 W TVS diodes such as SM712. The Pulse robust 10-ohms resistor are placed in front of the receiver to limit current flowing into the    device should the internal ESD structure ever conduct.
    Good luck, Thomas
    Report Abuse
    • Reply
  • Jeffrey Bledsoe
    on Feb 22 2012 08:48 AM
    Prodigy80 points
    We measured ~ -380 mV at the input to a single-receiver* circuit (Vin+ wrt Vin-) with the pins open-circuited; which results in a logic '0' at the receiver's output. In another instance of the single-receiver circuit, we measured ~ +380 mV under the same conditions.
    We don't know if it's a defective receiver or transzorb. We're returning it to the manufacturer for analysis and repair.
    Jeff
    * single-receiver means half of the diagram I posted earlier
    Report Abuse
    • Reply
  • John Goldie
    Posted by John Goldie
    on Feb 22 2012 10:02 AM
    Expert4995 points
    Greetings -
    With the rest of the circuit disconnected, the open-input failsafe feature should read with a positive differential input across the inputs due to internal high impedance pull up and pull down path.  The +380mV  sounds right.  The minus is not expected, and thus the reason for the output low as it is below the threshold.  If the device is measuring this, it has likely been damaged by EOS / ESD and can be sent for FA.  If however, this -380mV differential is seen in-circuit, then the external components should be reviewed to see what is impacting the bias to pull it low on that channel / device.
    John Goldie
    DPS APPS / SVA / www.ti.com
    Report Abuse
    • Reply
  • Jeffrey Bledsoe
    on Feb 22 2012 10:51 AM
    Prodigy80 points
    What are the terms for an FA?
    Also, a general forum usage question: What is the function of the green "Verify Answer" button on each post?
    Report Abuse
    • Reply
  • John Goldie
    on Feb 22 2012 16:57 PM
    Expert4995 points
    Greetings -
    Your local sales support person can assist on the FA policy and where to return a part to.  In general upon receipt the unit is retested and also inspected to see if some level of damage such as an ESD event has occured to the device.  A report of the findings is generated and provided.
    Best Regards;
    John Goldie
    Report Abuse
    • Reply
  • Jeffrey Bledsoe
    on Feb 23 2012 10:45 AM
    Prodigy80 points
    I couldn't find the expected open-circuit voltage across the inputs in the DS26LV32AT spec sheet. I know it should be a positive voltage but is there a minimum voltage magnitude I could look for in future testing?
    Report Abuse
    • Reply
  • John Goldie
    on Feb 23 2012 10:54 AM
    Expert4995 points
    Hi -
    You are correct, it is not a datasheet parameter, I would look for >+200mV differential (above threshold limit).  Pulls are weak current sources and are expected to vary somewhat over PVT thus not directly spec'ed.
    John
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
