• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Industrial Interface » Industrial Interface Forum » Industrial RS-232 to TS-422/485 Converter
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Hezi Lev
Posted by Hezi Lev
on Dec 27 2011 03:51 AM
Prodigy40 points
Dear fellows,
I am looking for Industrial RS-232 to TS-422/485 Converter with the following parameters:
Operating Temeperature : -20 to +50C.
Storage temperature : -10 to +50C/
Operating Humidity : Up to 97% condensing.
I will be glad to get information about relevant product.
B.R
Hezi
RS-422 RS232 RS485
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Thomas Kugelstadt
    Posted by Thomas Kugelstadt
    on Dec 27 2011 08:57 AM
    Mastermind25560 points
    We haven't got an integrated version but a 2 chip version for half-duplex RS485.
    For RS422 I can do something similar for RS422 (or full duplex RS485) but only if a two-chip solution is acceptable to you.
    Let me know,
    Thomas
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Dec 27 2011 10:14 AM
    RS232 to RS485 Converter.pdf
    Hezi,
    I have attached the pdf version on an isolated RS-232 to RS-485 converter. The article is published in Planet Analog and EE-Times. With regards to the Condensing issue, the only way I can think of protecting the circuit against high humidity is by using a hermetically sealed chassis.
    Regards, Thomas
    Report Abuse
    • Reply
  • Hezi Lev
    Posted by Hezi Lev
    on Dec 28 2011 06:36 AM
    Verified Answer
    Verified by Thomas Kugelstadt
    Prodigy40 points
    Thomas,
    10'xs for your answer. We will look for the solution that you have recommebded.
    B.R
    Hezi
    Report Abuse
    • Reply
  • Kepcoate
    Posted by Kepcoate
    on Mar 27 2012 17:59 PM
    Prodigy140 points
    Hi Thomas,
    How is the 2ms high time at data rate of 9600bps is calculated in the above article?
    "The time constant of the monostable output is defined by an R-C network with C
    = 220 nF, and R = 10 kOhm for a 2 ms high-time at a data rate of 9600 bps, and
    R = 100 kOhm for 20 ms at 1200 bps."
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Mar 27 2012 22:10 PM
    Hi Kepcoate,
    an old friend of mine used these delays for certain 485-protocols, which required a specified inter-packet delay, that is the time between one packet or character of data and the next one following. In the baove case I believe the interpacket delay was 0.75 T-char (the character time). A character or packet or whetever they call it nowadays typically consists of 11 bits: 1 start bit, 8 data bots, and 2 stop bits. At 9600 bps a character length is 11 / 9600 = 1.146ms. Dividing the 2ms by 1.146ms gives you a factor of approx.1.75, indicating that the high-time of the mono-flop is 75% longer than the actual character length. In Modbus RTU, another industrial protocol for RS485 data links, the inter-packet delay is even 3.5 times the character length or Tchar.
    So if you only want to keep the 485-driver active for the length of the character, simply divide the 11 bits by the baud rate you are using and then add 10% for temperature variation of the mono-flop and whatever percentage you need for covering the tolerances of the external RC.
    Regards, Thomas.
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Mar 27 2012 23:19 PM
    I just checked looked at a few older converter desings using mainly throughhole components. Here the older mono-flops or one-shot circuits had much larger tolerences. Also the resistors and caps used had 20% and 30% tolerances respectively.
    Hence as a rule of thumb I suggest make your time constant 1.5 x the character length. (which isn't too far away from the 1.75 above anayway).
    So I hope this simplyfies it. Good luck with your design.
    Regards, Thomas
    Report Abuse
    • Reply
  • Kepcoate
    Posted by Kepcoate
    on Mar 28 2012 10:54 AM
    Prodigy140 points
    Thanks for clarifying this further. That helped a lot.
    Report Abuse
    • Reply
  • Kepcoate
    Posted by Kepcoate
    on Apr 12 2012 14:44 PM
    Prodigy140 points
    Thomas,
    I was looking into selecting the wattage of 120 Ohm termination resistor. So I did some scope shots under no load and no termination condition. See below. CH 3 shows the RS485 differential output , CH1 and CH2  are A and B outputs with reference to GND. So pk to pk is roughly 10V.  Therefore P=VxV/R= 10x10/120 = 0.833W. This wattage seems high compared to 0.5W recommended by some app note online. Any thoughts or recommendations on this?
    Report Abuse
    • Reply
  • Leo Bosch
    Posted by Leo Bosch
    on Apr 12 2012 15:43 PM
    Intellectual690 points
    Hello Kepcoate,
    The Duty cycle (in the current flow) will be never 100%, in your example only 16%.
    I think roughly 50% would be enough, so 0.833 x 0.5 = 0.4165W
    -Leo
    Report Abuse
    • Reply
  • Kepcoate
    Posted by Kepcoate
    on Apr 12 2012 16:29 PM
    Prodigy140 points
    Hi Leo,
    If you look at the scope shot , if the bus is idle the 10V pk to pk is present 100% of the time. That is why  my calculations assume 100% duty cycle.
    Other thing is, per RS485 spec the receiver common mode voltage can be 19V ( -7V min to 12V max). Going with this number the wattage  is P= 19*19/120=3W. Not sure if I am doing this part correct.
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Apr 12 2012 16:37 PM
    Good day,
    the worst case condition is if A or B is constantly at 5V while the other output is 0V. Then you have 5V dc across a 120 ohms resistor which yields a power of 52 /120 = 0.2W.
    It is the differential voltage that determines the power dissipation in the termination resistor, not the comon-mode or ground referred voltage.
    Good luck , Thomas
    Report Abuse
    • Reply
  • Kepcoate
    Posted by Kepcoate
    on Apr 12 2012 16:53 PM
    Prodigy140 points
    Hi Thomas,
    If you look at my CH3 differential scope shot, it show 10V as differential. With just that number, I am getting 0.833 watt. The 19V is differential if -7V to 12V is common mode by reasoning of the attached scope shot. My scope shot is 5V on each A and B output w.r.t. GND but differential is 10V.
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Apr 12 2012 20:40 PM
    Hi Kepcoate,
    Channel 3 is the math-function of your scope calculating Va - Vb, it is not a real 10V drop across the resistor. The differential voltage across a 60 ohm resistor is approximately 2V (sometime even 3V), either in one or the other direction. The limited differential output voltage of less than 5V is due to the internal voltage drop across the driver output transistors. In your measurements without termination the only load is the 1M resistance of you scope probe.  Because there is only leakage current floating, no significant votage drop occurs across the output transistors and hence you can measure the open-circuit output voltage. Under loading condition however, with two parallel termination resistors and multiple transceiver nodes, Vod will drop drastically.
    Let's assume you have a common-mode output of Vcc/2 = 2.5 and a high output voltage of Vod = 3V under load.
    Worst case 1: When A is always high and B is always low then Va = Vcm + Vod/2 = 2.5V + 1.5V = 4V and Vb = Vcm - Vod/2 = 2.5V - 1.5V = 1V. The differential output voltage across a 120 ohm resistor is therefore Vod = Va - Vb = 4V - 1V = +3V.
    Worst case 2: When B is always high and A is always low then Va = Vcm - Vod/2 = 2.5V - 1.5V = 1V and Vb = Vcm + Vod/2 = 2.5V + 1.5V = 4V. The differential output voltage across a 120 ohm resistor is therefore Vod = Va - Vb = 1V - 4V = -3V.
    In both cases the power dissipation is P = V2 / R. Because V2 is always a positive number your can simply calculate P = (+/-3V)2 / 120 W = 75mW. So during normal operation and assuming no fault condition, you could easily use 1/10W termination resistors.
    However when considering fault conditions, the power rating of the resistors can go way up.
    Let's assume one end of the termination resistor at the far cable end looses connetion to the B-line but makes contact with the receiver ground instead. Let's further assume that the ground potential difference between driver and receiver is -7V. In the case that the driver output terminal A was high, the output voltage potential at A will drop suddenly to say 0.5V. Now you have a voltage drop of 7.5V across the remote 120 W resistor and the power dissipation rises to P = 7.5V2 / 120 W = 0.47W.
    Other fault scenarios can include accidental contact to parallel running 24Vdc power lines under full comon-mode, where termination resistors have power ratings of several watts.
    I hope the above clarifies the power calculation for your termination resistors.
    best regards, Thomas
    Report Abuse
    • Reply
  • Kepcoate
    Posted by Kepcoate
    on Apr 13 2012 11:00 AM
    Prodigy140 points
    First of all thanks for doing this effort to give a face to the 120Ohm termination wattage selection process.
    I did some measurement using 120||120 = 60 ohm load and I measure 66mW on 60Ohm. The CH3 voltage above was measured with a differential probe. Although the math function gives same waveform. The key is the 60 ohm did load the driver output quite a bit. From the above calculations it seems 1/2W will be in fact suffice for most cases.
    Thanks Again.
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Apr 13 2012 11:11 AM
    Glad I could help. - Thomas
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
