• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Industrial Interface » Industrial Interface Forum » adc conversion with high output voltage
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
    Engineering the world through Analog
    Posted 11 days ago
    by Hagop Kozanian
    Our lives are surrounded by analog everywhere we go. That’s...
This question is answered
badr ammour101188
Posted by badr ammour101188
on Mar 22 2012 05:41 AM
Prodigy100 points
Hello
I would like to find a good way in  order to do an adc conversion ( a circuit that i would link to a card)
 i would like to have in the entry of my circuit  an analog input of 400V, and i have a digital  output of 3.3V ( that is present in my card), of course i would like a secure' way (isolation if possible) in order not to destroy my card ^ ^.
I've seen on internet, but i've not really found a way to do it.
Is there any TI component and a model of circuit that would help me to realize this?
In fact while i'm writing these lines i'm realizing that i'm still mixing between  analog and digital I/O  (can anyone help undestand  this point please).
Thank you for your attention
Badr
adc conversion high output voltage
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Thomas Kugelstadt
    Posted by Thomas Kugelstadt
    on Mar 22 2012 12:29 PM
    Verified Answer
    Verified by Thomas Kugelstadt
    Mastermind25620 points
    what is there to understand?
    if you are desinging I/O cards for a PLC (programmable logic controller) you will have to distinguish between digital inputs and outputs and analog inputs and outputs.
    The HVS885 is a digital input chip whose eight 24V digital inputs are latched parallel inot a shift-register and clocked out serially via a digital isolator into a micro controller.
    The 400V analog input(s) are best accomplished by resistive voltage dividers feeding into a +/- 10V SAR-ADC or 5V delta-sigma ADC, whose low-volt digital output can be fed via a digital isolator into a micro controller. Unfortunately we don't have an integrated design or one-chip solution. You will need to accomplish this function with discrete components.
    does this help you further?
    regards, Thomas
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Mar 22 2012 14:16 PM
    Verified Answer
    I recommend consulting our data converter forum as they can help further with the appropriate components.
    Regards, Thomas
    Report Abuse
    • Reply
  • Thomas Kugelstadt
    on Mar 24 2012 22:21 PM
    Verified Answer
    Hello there,
    I have been calculating a little and voila, here is the 400V (+/- 200V) isolated analog input you desired. Please note that the design of Rin = 942k might require two resistors to make up the value, depending on the standoff or breakthrough voltage of the resistors you are using. Typical breakthrough voltages range from 50V, 75V, 100V, 150V and 200V. Manufacturers of high-voltage passives are Vishay and NOVA.
    The +/- 200V are divided down to a +/- 1.32V around a 1.65V mid-point for 0V input. Thus the upper, middle, and lower ADC input voltages are 0.9, 0.5, and 0.1 x Vref. With Vref = 3.3V the absolute voltages are 2.97V, 1.65V, and 0.33V respectively.
    Good luck with your design. -  Best regards, Thomas
    Report Abuse
    • Reply
  • badr ammour
    on Mar 27 2012 02:28 AM
    Prodigy60 points
    Thanks Thomas Kugelstadt for your help
    I really like your solution. On top of that there is isolation ^^
    Badr
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
