• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Industrial Interface » Industrial Interface Forum » ADS1118 followed by ISO7241C reads always 0XFF
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
    Engineering the world through Analog
    Posted 11 days ago
    by Hagop Kozanian
    Our lives are surrounded by analog everywhere we go. That’s...
This question is answered
Ankit Kumar
Posted by Ankit Kumar
on Apr 30 2012 03:15 AM
Prodigy160 points
Dear Sir,
I am using ADS1118 and to isolate the SPI port, i have used ISO7241C.
When i read data on MISO pin after ISO7241C, i always read 0xFF.
Is it due to the wrong isolator used because ISO7241C has TTL input thresholds?
Please guide me?
should i have used ISO7241M?
I also suspect that whatever i am sending to ADC is going as 0xFF due to ISO7241C...Am i right?
Please help?
digital isolator adc conversion
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Thomas Kugelstadt
    Posted by Thomas Kugelstadt
    on Apr 30 2012 10:33 AM
    Verified Answer
    Verified by Thomas Kugelstadt
    Mastermind25620 points
    Ankit,
    there can be many small causes why the interface is not working. The minimum SCLK-period of the ADS1118 is 250ns which results a 4MHz clock. The ISO7241C is a 25Mbps (12.5MHz) device. So the isolator is NOT too slow.
    1) When staring a data transfer you must at first pull the chip-select of the ADC low so it can read any information your are sending or activate its output for sending data to the ccontroller. Then you apply SCLK and send or receive data. Also the ISO7241 has two enable pins, EN1 and EN2, both of which must be pulled high to enable the output drivers.
     2) please also check that the ADC is configured correctly via DIN.
    3) please also check that the thermocouple you are using is working correctly. Simply apply some heat and check whether the output voltage of the thermocouple (mV-range) is changing from its initial value.
    4) If you have done this and it still does not work please send a schemtic and scope shots of your interface. Without seeing what you have designed I cannot guess or suggest any further actions.
    Regards, Thomas.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
