I want to build a controller for a machine with multiple sensors. The sensors are supplied with power either by the controller itself or have their own power supply. I want to galvanic separate the inputs to protect the controller against interference.
Is it enough if I galvanic isolate a common power supply for the sensor interface and the date lines from the rest of the controller, or it is better if each individual input has its own separate galvanic isolated power supply?
I have found an example of this in an application note from TI.
Industrial data-acquisition interfaces with digital isolation.
http://www.ti.com/lit/an/slyt426/slyt426.pdf
Analog Inputs:
2x 4-20 mA
2x PT100
I would be grateful for any help
