Hi
I design an inverter by using six ISO5500 to drive IGBT.
And I use a push-pull converter, which composed by SN6501 and TL431, to supply ISO5500 +15V (Vcc2, Vc) and -15V (Vee-l, Vee-p).
But, if I supply +5V to push-pull converter and ISO5500 together, the Vout of ISO5500 doesn't work.
The other way around, if I supply +5V to push-pull first and supply same source to ISO5500 later, the ISO5500 can work normal.
What problem does this inverter have? And how to solve this problem?
Thanks in advance for your answer.
