Dear Sir
Our customer use their RS232 Barcode Scanner with TRS213C ,The Barcode function is not workable
But Our customer change to use ADM213E (due to the schematic and package is the same) ,The Barcode function is workable
(This issue only happened with this Barcode scanner )
Our customer find our TRS213C's V+(Pin13) and V-(Pin17) voltage are abnormal
Could you kindly help to give more detail information about this issue? Do you have any suggestion could solved this issue??
