RS-232C to RS-485 converter
I found following document.
/cfs-file/__key/communityserver-discussions-components-files/138/0358.RS232-to-RS485-Converter.pdf
However, my customer require 250kbps/half-duplex.
Can it implement by changing cut-off frequency of the filter ?
Kuramochi
  • Kuramochi-san,
    Yes, the R/C values used in the monostable multivibrator circuit can be adjusted based on both the data rate and the length of each message frame. The goal of the circuit is to generate a "driver enable" pulse that will last the duration of each frame and then automatically switch the RS-485 transceiver back into receive-only mode.
    Max
