HI,
My customer need a CAN Transceivers to support 5~10Kbps Bit Rate,
could you please help advise if TI has a suitable CAN Transceivers to support 5~10Kbps Bit Rate?
Best Regards
Sean Zhang
HI,
Best Regards
Sean Zhang
On a further note, the SN65HVD23X line does not have a dominant time-out function that will hinder the minimum bit rate. You should be able to use this part at 5 kbps.
If you need a 5 V part the SN65HVD251 will also work.
