In the SN65HVD1782-Q1 datasheet MIN and TYP |VOD| are not provided for a load of 100 Ohm, a VCC of 3.3V and a temperature of 85C. Can you give me those values?
Thank you
Francesco
Thank you
Francesco
Francesco,
Unfortunately we don't have any characterization data with 100Ohm load and Vcc=3.3V. I can get the estimate based on the simulation for your reference. But it's not real characterization. Do you think it's good enough for your purpose?
Hao
Hello Hao,
Simulation results are sufficient. Is it something I can simulate myself? IF yes can you tell me how?
Thank you
Francesco
Francesco,
You can find the device ibis model here (http://www.ti.com/product/SN65HVD1782/toolssoftware). There are several simulators you can use, for example HyperLynx. The setup is straightforward. This app note (http://www.ti.com/lit/an/slaa747/slaa747.pdf) might be helpful. Please let me know if this route works for you.
Hao
