I can't found out the θJc Data in TRS3223EIPWR datasheet.
Could you please provide the data for me?
Seishin
Seishin
Seishin,
Theta JC for TRS3223EIPWR is 24.8C/W
If you plan to measure the top of case temperature to estimate the die temperature then PSI-JT which is 1.1 C/W is the value to use.
Psi-JT is much smaller than Th-JC because very little of the device heat leaves via the top of case to air.
Theta JC is helpful when heatsinks are used on top of case.
