customer want to connect 2 boards over USB HS and fears that the common mode (ground) can disturb the communication. Can the TUSB211 help and has it a wider common mode level?
Regards, Holger
Regards, Holger
Hello Diego,do you have a suggestion to solve the problem with the common mode? Unfortunately we do not have a USB HS isolation.
Regards, Holger
Hello Holger,
I am sorry for the delay. Unfortunately, I don't have a solution for the possible issue. But, giving a second thought if both devices are USB compliant there must not be any issue between the PHYs.
Diego.
