We are using TPS65982 in one of our custom design. We generated firmware and updated to flash. We are seeing some problem in one board as the negotiation is continuously happening.
I have used Type-C to power the PD under dead battery (Vin_3V3 is not valid). Also, I checked HRESET and MRESET pins for any toggling. There is no toggling @ those pins.
I have used totalphase PD analyzer to capture the logs and I attached the PD controller logs of working and non working platforms.
Is it possible to check the attached logs and suggest what could have gone bad in the non working platform?
/cfs-file/__key/communityserver-discussions-components-files/138/2068.PD_5F00_Debug.zip
With Regards,
Hariprasad Bhat
