HI Sir
May I know if the voltage set 20V ,how about the Vin range that TPS65982 can accept ??
19Vin or 18Vin ??
Hi Kai,
Yes, you can modify this setting by changing the "Under-voltage Protection Usage, PP_HV" in the "System Configuration (0x28)" register.
This setting can be changed from 5-50%, but be aware that increasing the percentage will not help in all the cases as other connected end might trat lower voltage as under voltage and stop working.
Rahul
