I have a question on TPS2553DDBVR Operating Junction Temperature.
Under Item 7.3 Recommended Operating Conditions spec, Tj max is 105degC for Iout=1.5A.
Under item 7.5 Electrical Characteristic, Thermal shutdown will occur at 135degC.
May I know what are the differences between these two items spec?
Does it mean for Iout=1.5A, the junction temperature measured/calculated cannot exceed 105degC?
What would happen to the device if Tj is more than 105degC? Operation will be disabled? And any tolerance of 105+- ?degC if the device hits max Tj before it disabled?
And per understanding, thermal shutdown will only occur at 135degC, right?
Please do kindly help to advise, thanks.
Philip
