Other Parts Discussed in Thread: , HD3SS3220, , TPS25910, TUSB422
This is to revive my previous thread, as it seems it's not getting any more answers.
Above the hub diagram I am trying to implement, I am not sure what to do here.
First, I have received the TUSB320EVM only to have read the manual and found out I need more than one EVM to even use it. Or am I being wrong? i cannot make a USB-C tablet to charge through it no matter what I do with configuration, or ID pin on the header. I was under impression the chip plus power switch should work to at least try to charge.
Second, I am not sure (after looking at the HD3SS3220, the chip recommended by the TI person who answered the previous thread) how to use it together with the TUSB320 to create a high current charging hub, the block diagram for which I showed in the beginning of the thread.
Could someone please provide a bit more detailed answer to this? Considering I do not have a whole lot of time to experiment, build a proto and find out it does not do what I hope it would? I am not very experienced in USB charging hub apps.
PS. I am trying to look through that manual for the TUSB320EVM.
The power diagram at the page 9 (DC_IN and uAB_VBUS diode-ORing into the TPS2590) doesn't seem to agree with how the schematic is, where the micAB_VBUS is the diode-ORed result of the TypeC_VBUS and DC_IN which then go to the TPS2590.
Mike.
