We are using the external MOSFET to support 20V/5A, but I have some questions about OCP test as below:
1.What is the overcurrent timeout setting? Can one have the graphic description?
2.Timeout setting can be set by GUI, could you recommend proper setting?
3.As far as I know that TPS65983 will control external MOSFET to limit output current when OCP occur,but the MOSFET will have large power dissipation(burnout risk) in this period.
How to select proper MOSFET base on the overcurrent timeout setting?
4.TPS65983 don't know external MOSFET state( ex. heat) in OCP period, how to ensure the MOSFET don't be burnout damaged?
5.Should I use the CC or CR mode to do the OCP test when using electrical load?
