Hi Support Team
Can you provide us with the maximum skew between the outputs?
Jeff Coletti
Hi Support Team
Jeff Coletti
This is not spec'd on the data sheet but when can infer the worst case skew using the Switching Characteristics tables. For example, for Vcca = 1.5V and Vccb = 3.3V with direction A -> B the minimum propagation delay is 0.5ns and the maximum propagation delay is 3.7ns. By subtracting the minimum value from the maximum value we can assume that the worst case skew between any two inputs at these voltages will be 3.2ns.
