Dear Sir,
for power source evaluation, I am calculating the consumption current of TXS0104 and TXS0108. Since I can't find the specification in the datasheet. may help provide it for evaluation? Thanks.
Table 6.5 of the datasheet specifies the static power consumption (ICCA, ICCB), table 6.16 the dynamic one (Cpd). (See the FAQ for what this means.)
Additionally, when you pull any pin low, there will be current and an associated voltage drop over the pull-up resistors and the pass-gate transistor; see sections 8.2/8.3 for their values.
Dear Sir,
I check the datahseet of txs0108 8bit consumption current is lower than Txs0104 4 bit, does it mean TXS0108 is more power saving , right? Am I wrong, please correct me, Thanks.
TXS0104 Icca+Iccb =max14.4uA,
TXS0108 Icca+Iccb= max 8uA
