Other Parts Discussed in Thread: SN74LVC245A
Hi Expert,
I want to use one SN74AVC4T774 IN SPI application and connect to two slave device. One slave device is close to CPU and 20CM for second device. How do you suggest to connect first device? Between CPU and SN74AVC4T774 or after SN74AVC4T774?
BTW, SN74AVC4T774 shows it's a tri-state output IC, it means can without the pull high resistor, right? Thanks!
