i have this component in my design.
Direction input is configured from A to B.
Output enable input is configured to be enabled (using a 4.75kohm resistor to GND).
By mistake the OE pin was shorted to 3.3V (resistor pull down to GND was still connected) and it seems to cause a voltage problem.
In general, i won't connect an input to a voltage without a resistor but, i want to understand why it cause a problem.
The input, OE, should have an input resistance that should protect it, i've tried to search DS to find it without luck...
Thanks in advance for your help,
Yoav.
