Other Parts Discussed in Thread: TXS0101
Hi Team,
One of my customer is using TXS0104E and observing issues with Signal Quality and signal Transition with Level translator usage in simulation.
Please note the issue Exist : Even if you connect MCU , Level shifter , NOR alone Ignoring(removing) all other transimission line , Via, terminations effect etc.
They are using Mentor Graphics Hyperlynx 9.4.1 and attached is the simulation waveforms and details.
Can you please look into the issue and let us know if there are known issues with the IBIS for this (TXS0104EQPWRQ1) part.
Also suggest solution for the same. IBIS Model used is Embedded in the Design.
Regards, Shinu Mathew.
