Hi team,
My customer has encountered a problem with ISO1050 when they use shielding on top of the IC case, they found the ISO1050 would cause the MCU into the fault state "BUS OFF" by transmitting/receiving wrong CAN data more than 255 counts. Please see the illustration below:
Shielding Image(need to make a cut-out for ISO1050 otherwise it transmit the wrong data on CAN):
Have you seen this issue before?
Thanks a lot.
Wei-Hao
