Hi Team,
This is a product with a specification upper limit of 50 Mbps. Is there a problem with using at low speed?
My customer wants to use at 9.6 kbps.
This device recognizes that it has not lined up for low speed.
Please let me know if there are points to be careful when using at low speed
I found the following.
”the lower-frequency range, where the interaction between the cable series resistance and the end-of-line termination results in attenuation of the signal. ”
If there is a possibility that V IT threshold will not be exceeded, what measures should be taken?
Kenji
