Other Parts Discussed in Thread: ISO1430, ISO1450
Hi Team,
When RE and DE are switched at the same time, the R waveform goes low for a moment.
I have found in E2E that this phenomenon also occurs in some other devices.
If DE is set to Low and RE is set to Low after 1us, this problem does not occur.Why does this happen?
What is the minimum delay required?
Is there a way to switch between DE and RE at the same timing so that this problem does not occur?
Kenji
