• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Logic » Logic FAQs » Cio Input/Output Capacitance
Share
Logic
  • Forums
Options
  • Subscribe via RSS
This question is answered
Mike Combs
Posted by Mike Combs
on May 14 2009 09:42 AM
Prodigy340 points
JEDEC – no definition offered
TI – The capacitance of an input/output (I/O) terminal of the device with the input conditions applied that, according to the product specification, establishes the high-impedance state at the output.
This parameter is the internal capacitance encountered at an input/output (I/O) of the device.  The values that are given are not production-tested values. Normally, they are typical values given for the benefit of the designer. These values are established by the design, process, and package of the device.
This tutorial is based on the Understanding and Interpreting Standard Logic Data Sheets application report (SZZA036).  To download the full PDF version of this application report, please use the following URL:  http://www.ti.com/lit/szza036
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom58603
    Posted by Tom58603
    on Oct 18 2010 08:52 AM
    Prodigy20 points
    As a circuit designer and board designer, how am I to use the input and output capacitance of a digital I/O device?  I know that a higher capacitive load affects timing.  But what other considerations (all of them) do I need to be aware of when connecting digital (CMOS/TTL) devices (processors, FPGAs, etc) as it pertains to Cin and Cout?
    Report Abuse
    • Reply
  • Chris Cockrill
    Posted by Chris Cockrill
    on Oct 18 2010 09:20 AM
    Verified Answer
    Verified by Chris Cockrill
    Mastermind32850 points
     Hi  Tom
    Cin and Cio are parameters that can be used for many calculations and modeling purposes, but the most common use and most important use is to insure the part meets datasheet spec in your system. It is very simple. The part will be specd into a specified load. It will meet specs driving  that capacitance or lower. Using the Cin you can determine how may parts you can drive and still be in spec. If your part is specd to drive 30pf then it could drive 3 parts with 9pf loads and still meet spec
    Report Abuse
    • Reply
  • Tom58603
    Posted by Tom58603
    on Oct 18 2010 10:34 AM
    Prodigy20 points
    Thanks for the quick response and the information!
    If the load capacitance is larger than what the driver can handle, will the output become unstable (like an op-amp driving into a large-C load)?
    I see that you had 3 loads, 9pF each, implying a certain amount of capacitance left over for 1) margin, and 2) board trace capacitance.
    You said that it is used for many calculations and modeling purposes.  Again, as a board designer, what modeling and calculations (besides the one we have talked about) should I also look at?  In other words, what are the top 5 types of calculations a board designer would do with Cin and Cout (besides making sure the driver can drive the load capacitance)?
    Thank you for your help!!
    Report Abuse
    • Reply
  • Chris Cockrill
    on Oct 18 2010 11:34 AM
    Verified Answer
    I am not a modeler so I cant help much with modeling questions.
    too much capacitance will not usually make logic devices unstable. most of our logic can drive more capacitance than specd but they may not meet the datasheet limits.
     More capacitance on the load will slow down the edges. Prop delays will slow down. Max frequency will decrease, low level may rise and high leve may decrease.
    So too much capacitance will move the output in between a high level an low level which might cause problems on the next part down the line.
    Here are some basic model comments. dont know much more.
    IBIS models, you would coose the capacitance closest to the actual load and run the model.
    SPICE models would have CIn and Cout of the various parts already in the model so you would just  give it board parameters and run it.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
