• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Logic » Logic Forum » Operation of TPIC6A259DW
Share
Logic
  • Forums
Options
  • Subscribe via RSS
This question is answered
JasonHaedt
Posted by JasonHaedt
on Jun 13 2012 16:29 PM
Expert2525 points
Although the data sheet identifies the recommended voltage of 0.85 VDD (4.25 V) as the VIH level, will the device work with the inputs operating at 3.3 volts maximum and 2.8 V minimum?  From our experience and testing, it does.  Is there any concern about operating the device in this way (long term reliability, loss or corruption of data, etc.)?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Avi Chami1
    Posted by Avi Chami1
    on Jun 14 2012 00:26 AM
    Mastermind7385 points
    What were the conditions for your tests? Did you test for all the ranges of temperature and humidity? Did you test for hundreds of devices, to see what happens with those that are relatively far from production average parameters?
    A logic device has a threshold. Its output is either low or high. If you push your working point behind the tested scenarios... you can get data corruption. Moreover, if the device input is very close to the threshold (wherever the threshold is), its output can start to oscillate, with the consequent noise generated to the rest of the circuit, and increased power consumption.
    There is always concern when you operate a device out of its tested and guaranteed limits. In this case: data corruption, noise, increased power consumption. I don't think this will affect long term reliability, since you are not violating absolute maximum ratings.
    Report Abuse
    • Reply
  • JasonHaedt
    on Jun 20 2012 09:48 AM
    Expert2525 points
    Thank you Albert for your reply.
    This device has been used in this manner for the last 4 years without any issues seen.  It has been tested over the full thermal operating range and been tested to 95% humidity.  Approximately 500 devices are used in this manner.  We have not seen any evidence of data corruption or noise on the outputs when we have set them using the address bits and control bits over all environmental conditions.  As state before, the Vih was a recommended operating condition in the data sheet.  Is there a way to find what the absolute minimum operating Vih is?  It seems to be much lower than the recommended.
    Report Abuse
    • Reply
  • Chris Cockrill
    Posted by Chris Cockrill
    on Jun 25 2012 12:58 PM
    Verified Answer
    Verified by JasonHaedt
    Mastermind32850 points
    Vih and Vil are the absolute max operating levels  and are guarranteed across temp and process. anything beyond that will void warrantee. However as you suspect they are highly guardbanded.
    Actual threshold of a CMOS device is 1/2 vcc and threshold of a TTL input 1.4V. They will shift with temp and process but usually not more than a couple hundred mv.
    If the part has a schmitt trigger input then there is a specified max and min.  These should be followed as stated.
    So, in summery.  Standard inputs Vih and Vil are heavily guardbandes and you will usually be safe if you cheat a little. However you do so at your own risk.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
