• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Logic » Logic Forum » Low power voltage translation
Share
Logic
  • Forums
Options
  • Subscribe via RSS
This question is answered
Andrey Limonchenko
Posted by Andrey Limonchenko
on Jul 11 2012 09:55 AM
Prodigy50 points
I'm looking on the best way to interface 2.2V and 1.8V systems. Direct connection draws ~40uA. I only have 20uA in my budget. I have tried a bus switch solution, but apparently they are optimized more for speed than for power, and all of them contain pullup resistors of 40K or less drawing too much excess current. I need two logic lines down, two logic lines up, and one logic line bi-directional. The speed is not critical to the design. Thanks for any thoughts on this.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Cockrill
    Posted by Chris Cockrill
    on Jul 11 2012 10:56 AM
    Verified Answer
    Verified by Andrey Limonchenko
    Mastermind32910 points
    High Audrey
     Not sure why you would need t translate since 1.8V is a good high for 2.2V Vcc. and 2.2V should not be too high for 1.8Vcc.
    Here is one way to do it.  This will require single parts for each line. this will be only about 6ua total.
    2 x SN74AUP1G34 for translating down with Vcc set to 1.8V and input can be 2.2V with output  equal to Vcc,  less than 1ua each
    2 x SN74AUP1T34  for translating up with Vcc set to 2.2V and input can be 1.8V with output  equal to Vcc or  you could use the AUP1G34 again but current might be slightly higher. Less than 1ua each
    1x SN74LVC1T45 for bidirectional translation, less than 2ua
    Report Abuse
    • Reply
  • Andrey Limonchenko
    on Jul 11 2012 11:10 AM
    Prodigy50 points
    Why does Page 5 has Delta Icc rating as 40uA:
    ΔICC     VI = VCC – 0.6V    IO = 0    3.3 V     40uA
    This means that when the inputs is not at VCC, then it's is going to draw extra 40uA?
    Report Abuse
    • Reply
  • Chris Cockrill
    on Jul 11 2012 12:22 PM
    Verified Answer
    Hi Andrey
    Yes The closer to Vcc or gnd the less current it will draw.  Or the closer you get to the switching threshold the more current it will draw.
    The AUP family is the lowest supply current parts we have. The AUP1T devices have their threshold lowered so that if you High is not quite Vcc it will stii be farther away from the threshold and draw less current.
    Report Abuse
    • Reply
    on Jul 11 2012 12:31 PM
    Prodigy50 points
    Is there a calculation to predict the current draw?
    Report Abuse
    • Reply
    on Jul 13 2012 12:05 PM
    Prodigy50 points
    SN74AUP1T34
     is not readily available, any suggestions?
    Report Abuse
    • Reply
  • Chris Cockrill
    on Jul 13 2012 12:24 PM
    The SN74AUP1G34 will work and it is in stock at digikey.
    Report Abuse
    • Reply
    on Jul 13 2012 13:35 PM
    Prodigy50 points
    Can I use SN74AUP2G126 instead of 2 SN74AUP1G34? I also like the OE option. The datasheet looks very similar. Do you know if it will draw more power?
    Report Abuse
    • Reply
  • Chris Cockrill
    on Jul 13 2012 14:07 PM
    it should not draw more power per gate.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
