I want use the SN74ALVCH16245 to transform the data which the rate is 150Mbps, is it correctly?
I want get the maxium data rate from the datasheet, but I did not find it. Please tell me which parameter reflects maxium data rate .
Hi Zhi
Fmax is 150Mhz so MBPS should be 300
Fmax will not be specd on buffers. It is only spec on devices with clocks. The easiest way to find Fmax is to look at a clocked part in that family.
I looked at the SN74ALVCH16374. It is best to choose a part with the same amount of outputs. or at least close.
