The datasheet for the quad buffer SN74LVC125ARGYR tells me that there is an exposed pad, but nowhere in the document it specifies which NET it should be connected to? Is this pad intended to be connected to GND, or to its own unconnected net?
If the datasheet does not specify where to connect the exposed pad, then it may be connected to ground or its own net.
