Hi Team,
Did we have the CVBS switch?
Here is the input and output.
Scott
Hi Adam,
Could you let me know both solutions? I can check with customer?
Scott
Scott,
I am not familiar with video conversion solutions so you may want check in some of the other interface forums to see if there is more information. I am however familiar with video signal routing. We have about 50-100 solutions for signal routing and would need to know some of the following to narrow our search:
1) What configuration? It looks like you want 2 channel 1:3 mux that will take 6 inputs down to two outputs.
2) What is the signal swing voltage and current of the signal needing to be routed?
3) What is the bandwidth of the signal being routed?
These will narrow our signal routing options to a manageable number of solutions
Thank you,
Adam
