Customer is considering SN74LV123A for a few seconds duration. Please let me know whether it is possible or not.
Kato
Kato
Table 7.3 of the datasheet puts no upper limit on the timing resistance, and no restriction on the timing capacitance. Using a sufficiently large resistor and capacitor will work (e.g., 1 MΩ and 1 µF will result in 1 s).
If you want the timing to be very precise, consider a low-tolerance capacitor type with low leakage current/high isolation resistance, such as PP foil (MKP).
Hi Clemens - san,
Thank you for the reply. In the case of 30s duration, please let me know what is the recommended parts and the value for Rext, Cext.
Kato
I designed a circuit in Tina by using SN74LV123A monostable multivibrator. In this design I expect 110ms tw at the output pin(Q) of SN74LV123A. According to tw=K*R*C formula I used 11k resistor and 10u capacitor to obtain 110ms tw at the output. But I obtain approximately 140 ms at the output and this value is not useful for my design. I used below formula to calculate tw value.
I used 2 SN74LV123A in this design. U1 is negative edge detector and U5 is positive edge detector.At the outputs(DIR and ROT) I expect 110ms pulse.
According to simation result I obtain approximately 140 ms pulse duration.Could you help me how I can obtain 110 ms pulse at the outputs?
