CD74ACT164 Timing diagram
Guru 16770 points
Other Parts Discussed in Thread: CD74ACT164, SN74LS164
Hi
Do you have timing diagram of CD74ACT164 or detailed logic diagram?
Could you share it with us if you have?
BestRegards
  • Hi.
    This is a standard 164 device, but unfortunately the datasheet lacks a detailed timing and logic diagram. Since this is the case, I would suggest referring to the SN74LS164 datasheet. It has a detailed timing diagram and logic diagram that you can use to learn how the CD74ACT164 operates.
    datasheet link: www.ti.com/.../sn74ls164.pdf
    Was there anything else you needed help with?
    Joe
