We are looking for a 24-bit bidirectional buffer (3.3V signals) with minimum propagation delay and skew. Can you please suggest us a suitable device?
Raja
Raja
Hi Raja,
It sounds like you're trying to find a transceiver (direction controlled bidirectional buffer). The absolute fastest devices we have are in the SN74AUC family, however they have a maximum voltage of 2.7V, so this application won't be able to use those.
Your best bet will be using our parametric search tool. I narrowed down the list here:
From my quick search, the SN74ALB16245 is probably the best fit, but I'll let you take a look and decide for yourself.
Thanks for the quick response.
As TXS0108E doesn't provide buffer operation, we are planning to use 3 SN74ALB16245 devices and connect all GPMC Address/Control/Clock/Data lines through this buffer.
I looked at the SN74ALB16245 datasheet and I have few queries to assess timing requirements for GPMC interface.
1. What is the delay from DIR pin to A or B ports? The datasheet mentions about OE to A/B delay, is it also applicable for DIR pin?
2. What is the skew across these channels (maximum difference in tpd for two channels)? I see tpd range from 0.6-2ns. Does it mean the skew is 1.4ns or does it mean that all channels will be delayed by same value and that value may range between 0.6-2ns and hence skew would be zero?
Raja
Hi Raja,
The delay for DIR is the same as that for OE - note from the logic diagram on page 3 of the datasheet that they have identical propagation paths.
The skew for logic devices is ≤ 1 ns (assuming equal loads) unless otherwise stated in the datasheet.
