Customer plans to use SN74LVC2G07 with output connected to a input of a chip with Vih(min)=2V. The output of SN74LVC2G07 output will be pulled up through the pull-up resistor to 3.3V.
By checking Choosing an Appropriate Pull-up/Pull-down Resistor (SLVA485), customer is asking the value of Ipull-up, but I can't find the corresponding parameter in SN74LVC2G07 datasheet. What is your comment here?
In parallel, I'm cross checking SCEA035A, and in page 8 it mentioned that max pull-up resistor should be chosen considering the rise time of the output signal. Will you also let us know how to decide the range of pull-up resistor value for such application scenario?
Thanks!
Antony
