Tool/software: TI-RTOS
hi,
i have a problem with myself chain, which is
capture(1280x720 16bits raw data, but i set the format yuv422i, both input and output format is yuv422i)
->vpe(to 1024x512)
->preprocess( yuv422 to rgb)
->tidl
->postprocess(to 1024x512 yuv420sp)
->display
and i use a 16bits wide but 12bits valid data mono-chroma sensor, so i do transform in capture process function, and transform the data to yuv422. then i can not see the correct display. before this work, i try the capture->vpe->display, the chain is ok, i can see the correct display.
i need your help, thank you very much. by the way ,how can i know my part number? i use tda2sx chip.
