Other Parts Discussed in Thread: TXS0102, TXS0101, SN74AXC1T45
Hi Team,
We use TXB0102 for level shift 1.8V to 3.3V bi-direction.
But we can not get 3.3V on B1 pin, only get about 1.8V. schematic as below.
1. Could you help to explain why? Is the driving current no enough?
2. We may change to TXS0102 for better driving capability. Use the same schematic, only change IC. Is the structure OK?
3. Customer wonder TXS can support push pull and open drain signal, why still has TXB series which can only support push pull signal?
Any advantage for TXB on push pull application?
