Other Parts Discussed in Thread: USB2ANY
In the TXS0108E data sheet, OE pin is pulled down to ground permanently via a resistor. Will this work for the normal operation after the device powered up?
Based on my understanding (by reading the datasheet), during the normal operation, the OE pin should be high. So after power up, OE pin should be pulled up externally, or not.
Thanks and regards
Wen
