• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » Seeking a low power proprietary RF TX/RX pair
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Artem Kamshilin
Posted by Artem Kamshilin
on Apr 13 2012 13:58 PM
Prodigy40 points
Hi everyone,
I'm trying to select a device family (hopefully a dev board to start with) to create something like the following:
http://www.phottix.com/en/wireless-remotes/phottixr-cleon-ii.html
Basically a two-channel one way digital signal transmission over 30-50ft range. I want to it to be free of international band restrictions (so that the same device is licensed in most countries, so I believe <1GHz is out). Ideally it would have some way of separating TX/RX pairs by channels, so that they don't mess with each other if operated in close proximity. Having a complex pairing procedure would be a disadvantage, so Bluetooth is out.
Ideally in the end I'd have a reference keyfob-like design that I could get into production with minimum customizations.
Anyone?
Thanks!
Arty
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chad Christensen
    Posted by Chad Christensen
    on Apr 13 2012 19:43 PM
    Intellectual980 points
    Something like the CC2510 would be able to do what you're describing. There's a mini dev kit that comes with 2 dev boards and a programmer for $75 (http://www.ti.com/tool/cc2510dk-mini). There's also a smaller USB enable version (http://www.ti.com/tool/cc2511usb_refdes). These work at 2.4Ghz and would easily do 50' outdoors and 50' in most indoor situations.
    As far as the pairing - would they need to be unpaired and re-paired by the user; or would they simply be paired once in production and remain as matched pair? Either way you could dedicate different channels to each pair so they won't interfere with each other.
    Report Abuse
    • Reply
  • Artem Kamshilin
    on Apr 13 2012 19:58 PM
    Prodigy40 points
    Hi Chad,
    Thanks, that board looks very good. I guess what I'm asking is how do two RX/TX pairs get separated - by using different frequencies (like GMRS radios) or by some sort of pre-shared code while transmitting in the same frequency? If it's the latter, then if two TX/RX pairs were paired at the factory, they should be able to co-exist in the same room and work independently of each other, and no further re-pairing work would be required?
    Arty
    Report Abuse
    • Reply
  • Chad Christensen
    on Apr 13 2012 20:57 PM
    The pairing scheme would depend on your design - if you use an existing protocol like ZigBee, blue tooth, SimpliciTI, etc., then you'll have to use what they provide (sorry I'm not familiar with those). If you don't use an existing protocol, you can do pretty much anything you can imagine. I've designed wireless smoke alarms that use a shared code while transmitting on the same frequency. Dozens of independent networks can work in the same room (or neighborhood in my case). This shared code could be pre-shared from the factory, or determined by entering a special pairing mode, or a combination of both (pre-share a code from the factory so everything just works out of the box, but give the option to un-pair and re-pair by entering a special mode).
    When operating multiple systems on the same frequency, only 1 unit can be transmitting at a time. This isn't a problem for many systems - my smoke alarms can simply wait 1 second if needed if someone else is transmitting (plus the odds of 2 homes in radio range starting a fire simultaneously are pretty low...). However, if you NEED to be able to handle 2 units transmitting at the same instant, then you'd need to separate them by using different frequencies.
    If you separate by using different frequencies, you can have multiple systems transmitting at the same instant in time without interfering. This is a little more complicated to implement, but very do-able with the CC2510 chips.
    Basically it's up to you and what your system needs -
    Report Abuse
    • Reply
  • Artem Kamshilin
    on Apr 16 2012 12:34 PM
    Prodigy40 points
    Thanks a lot for your help, Chad - I ordered the CC2510 board and will be testing it in the coming days.
    Arty
    Report Abuse
    • Reply
  • Artem Kamshilin
    on Apr 18 2012 17:35 PM
    Prodigy40 points
    Hi Chad,
    I got the kit, and it says "Not for use in Japan". I guess they just didn't go through the Japanese FCC with this particular board, but what about the CC2510 and its 2.4GHz range - is there a way to verify that something built on top of CC2510 can be used there?
    Arty
    Report Abuse
    • Reply
  • Chad Christensen
    on Apr 18 2012 19:15 PM
    I don't know why the board says not for use in Japan - maybe someone from TI knows the reason...
    I honestly haven't certified anything outside of the US / Canada, so I don't know about the exact regulations; but there is an application note here:
    http://www.ti.com/lit/an/swra060/swra060.pdf, Section 12 discusses Japanese requirements. I don't fully understand the details of the parameters they describe; but my understanding is that this chip is supposed to be able to pass the Japanese requirements. The CC2510 transmits in the open band for Japan, so it should be OK.
    You might also want to look into costs for getting certified in each region. My product with USA / Canadian testing and certification cost $5-10k. I'd guess around the same again for Europe and Japan.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
