• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » CC2520
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
CC2520
CC2520
This question has suggested answer(s)
Bruno Srbinovski
Posted by Bruno Srbinovski
on Apr 18 2012 14:06 PM
Prodigy30 points
I have recently designed a board with the CC2520 and the MSP430f5437.
The board  has a balun from Johanson Technology  optimized for CC2520 - 2450BN15B0002.
The board is 6 layer board with the stack up as follow:
The substrate in between the TOP and the GND layer is 0.8mm and the substrate between all the other layers is standard value.
1.Top - the CC2520 is located on the top layer
2.GND
3. Power-V=3.3V
4.Signal_1
5.Signal_2
6.Bottom - the MSP430f is located on this layer.
I was successfully able to send data packets between two pcb's using the provided example code, but now I have started to look at the RF output on the spectrum analyzer and I am getting only -11dBm when the transmit power is set at max 0xF7. I used the following registers settings to perform a carrier test:
Included is the picture of the top side layout. Please advice to why I am getting only -11dBm. I did expect a few dBs of attenuation but -16dB indicates something major is wrong.
CC2520_MEMWR8(CC2520_TXCTRL,      0x94);
 CC2520_MEMWR8(CC2520_TXPOWER,     0xF7);
CC2520_MEMWR8(CC2520_MDMTEST0,0x65);
    CC2520_MEMWR8(CC2520_MDMCTRL0,    0x44);
CC2520_MEMWR8(CC2520_FRMCTRL0,    0x43);
    CC2520_MEMWR8(CC2520_FRMCTRL1,    0x00);
    CC2520_MEMWR8(CC2520_EXTCLOCK,    0x00);
Part from my main:
  Command_strobe(CC2520_INS_SXOSCON ); //Oscilator ON
  Command_strobe(CC2520_INS_SNOP);
 Command_strobe(CC2520_INS_STXCAL);
 Command_strobe(CC2520_INS_STXON);
while(1);
4276.CC2520_MSP430_43mm_BALUN_1.pdf
CC2520 output power issue
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tor-inge
    Posted by Tor-inge
    on Apr 19 2012 01:51 AM
    Expert3205 points
    Hi Bruno
    I have had a quick look at your design and found no obvious explanation to a 16dB performance drop. Review in pdf is difficult, gerber files would provide a better base for checking the design, a schematic also is helpful.
    The register settings seem Ok. One comment TXCTRL=0x94 is only intended for high temperature operation, else it should be 0x91
    Suggest start checking component values, solder joints and  supply voltage on al VDD pins to debug the design. Sometimes current measurements also provide clues to what is happening.
    Tor-Inge
    CC2520
    Report Abuse
    • Reply
  • Bruno Srbinovski
    on Apr 19 2012 07:53 AM
    Prodigy30 points
    HI Tor-Inge,
    I can now verify that the board is fine. It is something with the procedure for going  to TX mode.
    When I put a break point in my code, after performing command strobe for calibration (INS_STXCAL) and wait roughly for 10 seconds, I get full power (3dBm) on the spectrum analyzer. It seems like the radio is not in transmit mode if I don't delay long enough even though the current is 34mA. So I guess that my procedure for getting in the TX mode is not correct. Can you please advice me what is the right procedure for going in TX mode after resetting the CC2520? I include the register setting and the part of the main:
    Register settings:
    TXCTRL->0x94
    TXPOWER ->0xF7 //5dBm
    MDMTEST0 ->0x65
    MDMCTRL0 ->0x44
    FRMCTRL0 -> 0x43
    FRMCTRL1 ->0x00
    EXTCLOCK -> 0x00
    Part from Main:
    Reset ;  // resetting the CC2520 AS per example code
    __delay_cycles (500); // I run at default frequency through the DCODIV
      __delay_cycles(500);
    __delay_cycles (500)   // I put the break point here and wait for roughly 10 sec and then hit play and I am getting the full power. If I don't wait the attenuation is 16dB.
    Command_strobe(CC2520_INS_TXON);  // The current is correct I = 33mA
    x = Command_strobe(CC2520_INS_SNOP );  //Check of the status byte.
    while(1);
    To summarise:
    If I do not breakpoint on delay after TXCAL strobe I get 34mA and only -11dBm output, if I delay for 10 seconds I get 3dBm as expected.
    Report Abuse
    • Reply
  • Tor-inge
    Posted by Tor-inge
    on Apr 23 2012 01:40 AM
    Expert3205 points
    Hi Bruno
    This is a bit outside what I am familiar with. Hopefully, someone with low level programming skills can comment on this.
    However, it is my understanding that there are two approaches to this. First, strobe STX and transceiver will calibrate and automatically start transmission of TXFIFO content after calibration. Second strategy is to monitor FSMSTAT0.CAL_RUNNING for a negative edge indicating finished calibration.
    Tor-Inge
    Report Abuse
    • Reply
  • Jani Kyrola
    Posted by Jani Kyrola
    on Aug 07 2012 03:37 AM
    Suggested Answer
    Prodigy20 points
    Hi Bruno,
    Did you find solution to the problem? It seems that we have similar issue. We are using also MSP430f5437A and cc2520.
    We are missing ~15dm from CC2520 output. Changing the TXPOWER register does not make any effect to radio output.
    -Jani-
    Report Abuse
    • Reply
  • Bruno Srbinovski
    on Aug 08 2012 01:49 AM
    Prodigy30 points
    Hello Jani,
    I found solution to my problem by building my own state machine for each of the modes (TX,RX,IDLE,LPM1,LPM2). So, if I want to go from LPM1 to TX I execute one piece of code if I want to go from RX to TX another piece of code etc. I was following the flow diagram on page 85 in the datasheet.  Here is a code example :
    First reset the CC2520 with using RESETn, then initialize (registers) and then I call this function set_radio_mode  and put the radio in IDLE .
    status = set_radio_mode(Radio_IDLE);//Go in IDLE
        Command_strobe(CC2520_INS_SFLUSHRX); //  Flush RXFIFO
        Command_strobe(CC2520_INS_SFLUSHTX); //  Flush TXFIFO
       CC2520_TXBUF(mpduLength,txMpdu); //Write to the TXFIFO
        status = set_radio_mode(Radio_TX);//Go in TX
    unsigned char set_radio_mode ( unsigned char mode)
        case Radio_TX:
           if (Prev_Radio_Mode==Radio_LPM1) //if the previous radio mode was LPM1 I do the following sequence of commands
                P3OUT&=~1; //CS
                    while (!(P3IN&BIT2));// wait until SO<>1
                P3OUT|=1;
                while(!(Command_strobe(CC2520_INS_SNOP)&0x80));
               // now oscillator is stable and running
             status = Command_strobe(CC2520_INS_SNOP);
            else //if (Prev_Radio_Mode==Radio_RX)
               status=Command_strobe(CC2520_INS_SNOP);
         Prev_Radio_Mode=Radio_TX;
        break;
        case Radio_IDLE:
                Command_strobe(CC2520_INS_SXOSCON);
                Command_strobe(CC2520_INS_SRFOFF);
            Prev_Radio_Mode=Radio_IDLE;
        break;
        case Radio_LPM1:
            Command_strobe(CC2520_INS_SXOSCOFF );
            Prev_Radio_Mode=Radio_LPM1;
        break;
    Good luck,
    Bruno.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
