• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Hardware & Tools Forum » CC1101 OOK vs FSK
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
CC1101 OOK vs FSK
CC1101 OOK vs FSK
This question is answered
Michael Gearhart
Posted by Michael Gearhart
on May 03 2012 09:25 AM
Prodigy140 points
I have redesigned a client's legacy rf system to maintain compatibility with an older system.
The transmitter is a Microchip rfPIC12F675 with a short preamble (14-bits) and then transmit 16-bits data at a data rate of 4.055K using OOK and Manchester Encoding.   The transmitter has a small loop antenna on the PCB and is worn on the wrist or ankle.   This message is transmitted approximately every second.
I have a msp430F2618/CC1101 receiver located at doors to prevent the person wearing the transmitter from exiting.   I use GDO0 as Carrier Sense (CS) to call my isr when the CS goes from low to high.  I then read the incoming data on GDO2 as Manchester encoded and translate to a binary ID.
I need to set a user-defined distance where the transmitter is ignored if outside the defined boundary of typically 4 - 20 feet..  I accomplish this by configuring the CC110x at a constant AGCCTRL2,  AGCCTRL1, and AGCCTRL0 and then using a SkyWorks SKY12329-350LF to attenuate the rf signal entering the CC1101 0dB - 30dB.  There will be times during the night when there will be no rf transmissions being read and times in the afternoon when it will be reading several transmitters simultaneously.  As a person approaches the door the power level read at the receiver will increase so there is really never a constant power level of transmitter to work with as there would be with two fixed locations.
The Problem
The receiver reads the transmitter erratically.  Can set the distance at 9 feet on Thursday and everything working great at the end of the day.  Get a call on Saturday morning the receiver is somehow now reading transmitters at 50 feet.  Then get a call on Monday afternoon that a person wearing a transmitter is standing 4 feet in front of the door and not being read at all.
Sometimes get calls from the field that the receiver has "gone to sleep" and is not reading any transmitter at any distance after it has worked fine for weeks.
I understand at some level that the CC1101 RSSI is not a precise variable but my personal opinion is that most of my problems stem from the internal workings of the CC110x operating in OOK mode.  By this I mean the problem is not primarily in my code interfacing with the CC110x with the possible exception of my configuring of the CC1101 (that admittedly could be less than optimal, it is a complex part). The msp430 periodically monitors the CC1101 state and will reset it if the CC1101 seems to be operating in an unexpected manner.  It also periodically manually calibrates the CC1101.
Part of what leads me to this conclusion is the Design Note DN022 devoted entirely to overcoming the CC1101 being unstable in OOK mode.  I have also spent hours with a logic analyzer and can see that sometimes the CC1101 just stops sending data to the msp430.  It is not that the CC1101 is sending data and my code is fumbling it somehow.
The Question
It did not really hit me until I read a E2E entry recently that my receiver board design is the same regardless of my using OOK (as I am doing) or FSK.    I could create a second series of transmitters that work using FSK and continue to supply the OOK transmitters for replacement parts for the older system.  The receiver board could be programmed as either OOK or FSK to support old or new configurations.  Would changing to FSK solve some of my problems?
CC1101 OOK
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sverre
    Posted by Sverre
    on May 04 2012 13:16 PM
    Verified Answer
    Verified by Michael Gearhart
    Genius14060 points
    With FSK you get register settings through SmartRF Studio. In your case you can simply use the 4.8 kbps settings and just change the data rate.
    When using OOK mode you need to do a lot of measurements to find the optimum settings that ensures good reception across the full dynamic range. It is doable as outlined in DN022, but if you have the option to change modulation format I would suggest a move to FSK.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
